Modernization question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2010, 07:24 PM
I'm wanting to do a frame-up resto on my 87 silverado... But i want to modernize all of the engine and drivetrain... Does anybody know if my truck body will fit on the frame of a 2000-2003 silverado??
Old 02-01-2010, 09:36 PM
I don't know about the cab and bed mount points but those can be changed. what you need to know is the wheel base and overall frame length.
Old 02-02-2010, 09:19 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Horsepower tv's show trucks put a ford cab on a dodge. I imagine if you got a welder and are good at fab work you should be able to do it.
Old 02-02-2010, 12:12 PM
Then it's not a resto...
Given enough money and welding rod you can do anything, but that doesn't make it a good idea. The later model frames are considerably wider than the ones under the 73-87 trucks - note how your steering box is outside the frame rail and the later model ones are inside. Same for the gas tank.
It's very easy to install an LS-series engine and trans in your truck. You can get upgraded brakes. The rest of the late model chassis isn't different enough to warrant the work. Just swap the engine and trans.
Old 02-04-2010, 12:52 PM
i've thought of that too but i want to drive my truck as long as possible... thats why i was thinking of using a different frame... eventually i want to put an ls7 and a 6 speed stick in it so i figured i would get a newer frame and do some fab to it and put all the aftermarket performance parts on it so i just have to put my body on it when i'm done...
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Fuel System question Ratoflic Engine 5 01-23-2010 11:04 AM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
