Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Modify TPI
Thread: Modify TPI
Old 10-16-2010, 01:15 AM
stroker444 stroker444 is offline
Modify TPI
I know that TPI is barely enough for a 305, but I would like to install one on my 383. Im in tech school and will be in the high performance class in a month. They have EVERYTHING necessary to program, port, dyno. Like I said.. everything. I want to get a tpi system, port it where necessary, install bigger injectors and throttle body and dyno/tune it. I would just get a holley stealth ram, but they are expensive. Im sure I can get a stock tpi close to where a stealth ram is, right? This is a street car where tourqe matters the most.
Does anyone have any info onto why the tpi is such a restriction, ie the areas that need focusing on? Thanks!
