modifying glide shift point - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2010, 05:12 AM
Can I modify the governor on a glide to make it shift at 7000 to 7200 in drive at wot?
Old 02-19-2010, 07:09 PM
junior stocker's Avatar
Never heard of anyone doing that. You can adjust the throttle pressure valve internally, but that's only good for a couple of MPH. Is there a problem with shifting it manually? I have one Glide that has an internal electric shift; it can be wired into the shiftlight to shift at a predertimined RPM. King and TSR both make them. Butch/junior stocker.
Old 02-20-2010, 04:53 AM
No problem with manual shifting, just looking to remove a variable for bracket racing.Figured it might be a little more consistant.
4L60e 2-3 shift slow after installing kit ckucia Transmission - Rearend 3 09-01-2009 11:09 AM
700r4 shift / tv question mican99 Transmission - Rearend 3 05-04-2009 09:08 PM
Modifying th350 valve body at home - Custom shift kit? Warrant Transmission - Rearend 5 11-24-2006 07:39 AM
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 09:20 PM
TH400 shift point...help Ted655 Transmission - Rearend 1 10-14-2002 11:18 AM
