Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - "Modifying" SBC Oil Pan
Old 05-14-2012, 09:26 AM
Dougie Dougie is offline
Now that I have the SBC, Muncie and Ford rear end installed in the '62 Studebaker Lark, and have the pinion angle set, I have a clearance issue with the steering arm (old time center steer on Studebakers) and the front of the oil pan. When you turn the wheel, the arm scrapes the bottom front drivers side of the oil pan. Some others who have done this swap have mentioned using a slightly taller motor mount, or adding 3/8" shims under the mounts to give it clearance. I'm afraid either will screw up my pinion angle and it will be difficult to raise the trans on the rear crossmember due to claerance issues there with the linkage.
Since the oil pickup is in the rear of the sump, would it be acceptable to "massage" that spot on the front of the pan with a hammer? I can access it without removing the pan. Any thoughts? Thanks,
