modifying stabilizer bar bushing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 11:44 AM
andrewakessler's Avatar
This may be a strange question, but I purchased some Moog stabilizer bar bushings that were suppossed to fit my frame but upon testing don't seem to fit (G body Monte Carlo). Looking online, it seems the only type I can buy that will fit the frame correctly are rubber, but I'd prefer to use the poly bushings. Is it possible to cut the bottom of the bushing so that it will fit correctly? Would it affect anything?
Obviously since bushings are so cheap it's not about saving money, it's more about using a poly bushing.
Thanks,
-A
Old 08-20-2012, 11:30 PM
bigdog7373's Avatar
Of course it's fast
You see how theres a circle one the side there in the picture. Don't go past that and you'll be fine. A lot of these kits are a one size fits all kinda deal.
Old 08-21-2012, 06:57 AM
Wiki Edits: 27
bandsaw ?
If you have a bandsaw you can trace rubber or poly bushings on a piece of 2 X 4, cut out the wood then stick the bushing in the cutout,,Put in a piece of broom handle or bolt in the hole,, the wood will hold the bushing to minimize distortion as you cut it.
Old 08-21-2012, 07:30 AM
Thanks for the help. I had a theory I could cut all the way down to the outer circle on the bushing but wanted to make sure the tab wasn't vital to anything.
bushing driver- trans. pump bushing. Chevy350Sb Garage - Tools 2 10-14-2009 09:45 PM
Tips on how to bend a stabilizer bar? staleg Suspension - Brakes - Steering 3 08-06-2008 02:55 PM
Sway Bar bushing blues bowtyebob Suspension - Brakes - Steering 6 11-27-2006 05:58 AM
72 Nova Front Stabilizer Bar Bushings leejoy Suspension - Brakes - Steering 2 03-21-2006 08:16 AM
Basecoat Stabilizer jcclark Body - Exterior 5 03-30-2005 12:05 PM
