There are quite a few things you can do to modify a trans without using a shift kit like remove all but one check balls, remove accumulator spring,....
I have only done one th350 so Ill leave that answer up to someone else... for those of you doing 400's this is something I do to all mine and gives a very violent shift 1) Full seal and bushing replacement 2) HD Kevlar Bands 3) Kolene steels 4) Red Eagle Frictions 5) Swapped out direct housing for 1968 housing (or ealier) 6) 4L80e forward piston and clutch hub to allow for extra friction and steel. 7) Switched forward and direct piston release springs 8) Removed center seal from direct clutch hub 9) Plug in reverse feed to center support w/ .25 plug 10) 34 element sprag 11) Hardened output shaft 12) Removed 4 check balls. RND/3rd clutch/2-3 Dr 13) Increased 2nd clutch feed to .110” and 3rd clutch feed to .184” in spacer plate 14) Removed 2-3 accumulator spring, and replaced plastic piston with aluminum piston w/ cast seal and installed upside down. 15) Removed 1-2 valve spring and replaced with ¼ copper tubing @ .95 long to block piston. 16) Shimmed Pressure regulator spring Last edited by gilby246; 10-20-2006 at 07:32 PM. |
there is one valve to block in place..... the trans will down shift from 3rd to 2 gear or 1st at any speed.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
anyone else? confirm what to do and which valve? What can I block this valve with?
Also will blocking wich ever valve change the way the transmission operates or behaves? ofcourse it will allow you downshift whenever (I would guess that valve is thier to prevent damnage to the engine in trans) Thanks |
not sure how much you know about the t-350 v-body.... I do not have a photo of one for visual reference. look at the v-body with the passages side UP so you can see the valves in the bores..... do you know which valve assembly line up is the pressure regulator ? I hope so. the valve to block for down shifting to low gear at ANY speed is the valve on the other side of the v-body. To recap; IF the pressure regulator valve line up is on the left side as you look at the v-body.... the valve to block is a small one the right side . There are several passages with sleeves & valves in them. PR on one side , the valve to block on the opposite side. Block it with a stiffer spring OR cut out a short section 5/16 steel cooler line tube . Make SURE the retaining pin & bore plug will not fall out!
| GM fast burn heads | batman09 | Engine | 1 | 10-26-2004 09:32 AM |
| TransGo 700 Performance Shift Kit Problem | edge | Transmission - Rearend | 1 | 08-02-2004 12:47 PM |
| slight clunk/ shift kit install Q's | HARVICKx29 | Transmission - Rearend | 2 | 02-16-2004 09:51 PM |
| TH350 Modify stock valve body to full manual | Mr. Horsepower | Transmission - Rearend | 7 | 05-26-2003 10:21 AM |
| AOD Valve Body ?s | mustang66maniac | Transmission - Rearend | 3 | 03-15-2003 02:12 PM |
