Modulator hook up
22K views 7 replies 5 participants last post by  joe_padavano
I recently swaped in a th400 into my 1988 k5 blazer with a 383. I noticed that my shifts are a little late so I know I have to adjust my vacuum modulator but before I do I wanted to make sure that I have it hooked up to the right vacuum port. Right now its hooked up to the carb which is a holley 650 street avenger:
I've been reading that it should be hooked up to the intake (i have a edlebrock performer intake) but the only vacuum port I can see on the intake is the brake booster port and I don't think I can tee into that because that line is a lot bigger than my modulator line. Will that carb hook up be enough? Also this engine makes less vacuum because of the cam (not sure how much less because I've never tested it)
I actually messed up, that line in the picture is the vacuum advance line coming off the distributor. My modulator line is acually hooked up to a port on the base plate of the carb, I downloaded a 670 manual and found out I have it hooked up to constant full vacuum so its hooked up right. I'm going to adjust the screw counterclockwise and that should solve my problem.
