-   -   modulator needed? (http://www.hotrodders.com/forum/modulator-needed-89136.html)
BBCMudbogger 05-11-2006 07:45 PM
modulator needed?
I have a TH400 with an auto/manual kit and it is going into a mudbog truck offroad only. Can I get rid of the modulator all together if not planning on running in auto?
Crosley 05-11-2006 08:09 PM
main line pressure will go real high with no modulator ...... 300+ psi usually
BBCMudbogger 05-12-2006 05:43 AM
Is that good or bad?
IanRiordan 05-12-2006 05:58 AM
B & M used to make a 'tv cable' style replacement for T400 modulators in the late 70's for blown/turbo applications. I never saw one in the flesh - only magazine articles. Why don't you want a modulator?
tnsmith10 05-12-2006 06:09 AM
odds are that with the engine hes probably running, the motor probably wont pull much vacuum... kinda makes a modulator worthless
Crosley 05-12-2006 08:14 AM
lol ........ bad
BBCMudbogger 05-14-2006 08:17 AM
Vacuum is the issue. Hopefully the motor will be pretty nasty....lol......253/261 duration solid roller.......will be launching at about 3800-4000 I suppose. I am going to get an electric vacuum pump for the brakes. Maybe I can rig something for the modulator, but I don't want to if I don't have to.
Crosley 05-14-2006 11:56 AM
one item to remember is the auto/manual v-body will only upshift at a higher RPM with no moulator on the tranny or if it is unhooked.
A full manual shift v-body would shift to any gear at any RPM.
There are mods that can be performed to close off the reverse boost circuit to not have a high line pressure problem in R .
:cool:
IanRiordan 05-15-2006 04:03 AM
Check a euro diesel out. Whilst most diesel duallies run a hydraulic booster, Benz's etc run a compact vacuum pump. You could easily rig a pump from a 2000 up M/Benz cdi and a throttle controlled switchover valve from an 81 - 85 300d/td for the trans.
Easy to set up and CHEAP.
BBCMudbogger 05-17-2006 03:55 AM
The switchover valve does what? I am guessing it reduces vacuum at WOT? Thanks for the input.
IanRiordan 05-18-2006 02:31 AM
Switch over.
Yes, the switch over valve found on the rocker cover of 81/85 300Ds has 3 vacuum ports - inlet, outlet and bleed off. It's as small as a kickdown switch and could be fitted to most any cable or linkage. Plumb the wot bleed off back to the booster and you will have normal vacuum booster and modulator operation regardless of available vacuum.
red65mustang 05-18-2006 03:15 AM
the modulator is adjustable for vacuum Hg/shift points, 3800 rpm launch is lots of Hg
the brakes have a one way check valve so the booster holds whatever the max Hg is above idle (ex:25Hg on a downshift, excellent check valve will hold it for 2 days with the motor off)
if the idle Hg is so low (below about 12Hg) that the brakes don't work due to the cam, you can't tune the carb
if you want to (????why) be able to turn off the modulator, just add a $5? inline manual on/off barbed valve to the modulator hose
I tried a ten turn fine adjust on/off valve once, to see if I could adjust modulator diaphram reaction time, didn't work on a C4,
IanRiordan 05-19-2006 03:39 AM
I'm assuming a BAD roller (260 @ 50 or more) so I treat it like a blown application, if it can find 12 inches then forget everything and run a stock mod.
Im guessing that by the posters name this thing will be run like a light switch - on or off which means no vacuum.
I'm pretty sure the M/Benz sprinters I spoke of are badged as Dodge or Fruitliner vans in the US.
