Modulator valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 11:15 PM
Modulator valve
Hello. I have a Turbo 400 transmission and 350 SBC. Transmission has not been used for months. I took it out today and found that it was not shifting. Properly. It seems to be stuck in 1st of second. If I put it in 2nd and then slip it into 1st I can feel a downshift but then if I shift from 1st to 2nd or drive I feel in shift. Can anyone tell me where the Modulator valve vacuum line should hook to in the engine compartment? At present I have it running into the vacuum port on the intake manifold. Also, I read an old post here that said that inside the vacuum tubing on the modulator valve there is a small flat head screw that is to adjust when the transmission shift. Have you heard of this? Thank you for your help.
Old 01-26-2012, 03:50 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
As long as it's hooked to a full vacuum source.
You should be fine hooked to the intake that is /should be full manifold vacuum, and yes it's true there is a adjustment in most of the modulator valves, and a flat head screwdriver is the tool most use to adjust it. JMO
Cole
Old 01-26-2012, 08:06 PM
Shifting is controlled by the govenor under the round cover. You can change weights and springs to adjust shifts , much better. Takes 10 minutes, if done before.
Themodulator has a stright slot adjuster down the nipple barrel.
modulator valve fast 79 malibu Transmission - Rearend 1 04-26-2008 09:52 AM
modulator valve th350 studebaker46 Transmission - Rearend 1 02-12-2007 04:28 AM
modulator valve, please help Turbo Terror Transmission - Rearend 1 04-07-2005 04:05 AM
modulator valve? TonyMac Transmission - Rearend 2 04-28-2004 06:01 PM
modulator valve its4pla Engine 3 02-14-2002 03:13 PM
