modulator valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2002, 05:21 AM
Question modulator valve
Should a mod. valve vacuum line be hooked up directly to the intake or to a ported source on the carb? If carb is the answer,which port?
thanks
Old 02-13-2002, 06:28 PM
Tom Tom is offline
Post
the modulator valve should be connected to the intake manifold directly, usually there is a vacume tree just behind the carb,ported vacume will give the wrong signal to the tranny
Old 02-14-2002, 01:10 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Question
this may be a dumb question, but what does a modulator valve do?
JB
Old 02-14-2002, 03:13 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
JohnnyMopar, a modulator valve makes the Trans shift
