modulator valve th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2007, 06:28 PM
i have an early 80s 350 behind a 350 engine. the problem is i drove the truck home one night and all was fine the next morning it would not shift into third. i have had this problem before and it was a broke vaacum hose to the mod, the line was fine. how do i check the modulator. thanx
Old 02-11-2007, 08:14 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
The transmission shifts by governor. The modulator over-rides the governor. If the mod line is disconnected, only the governor works (5000 rpm shift).
Connect the mod hose to the manifold vacuum and drive it.
Old 02-11-2007, 08:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
vacuum pump of the hand held type will pull a vacuum on the modulator. IF it holds the mod is good.
Pull the vacuum hose off first for a check for any trans fluid out of the hose nipple on the modulator..... trans fluid there equals an internally bad modulator.
200R4 to TH350 JohnyR17 Transmission - Rearend 4 10-18-2006 11:43 PM
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 09:45 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
