modulator valve th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2007, 03:47 AM
i have an early 80s 350-350 the trans will not shift into third. night before was fine the next morning no shift. how do you check mod. thanx
Old 02-12-2007, 04:28 AM
Hook up a mighty vac (vacuum pump) to the mod and pump it to 20 inches, if it holds this for 10 minutes then the diaphragm is ok. If your mod is adjustable, use a depth gauge to check the plunger position and set it to match a non adjustable one.
If it only drops into 3rd when you lift off it could be 2/3 shift valve, stuck modulator valve (not mod itself) or governor,governor valve.
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 09:45 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
Swapping a Muncie m465 to a TH350 TL-Iguana Transmission - Rearend 2 12-26-2003 10:32 AM
