I've used a 10K, 2 post Mohawk lift in a professional repair shop for over 30 years. I've spent maybe $200 on maintenance over those years. In my book that's tough to beat.
we use mohawk at the college here, seem to be a good lift
I have had a mohawk lift for about 20yrs and I have not had any problems, always works and is very safe. I also have 4 4000lb jack stands that are always placed under the cars. Mine is the 6000lb version. I have no regrets on buying a mohawk lift.
Mohawk. The Rotarys I have had just did not hold up as well. Whichever you choose...get a professional maintenance plan! Let the guys who built it look it over every now and then to make sure it's a-ok. And LISTEN to what they say! If they say it needs something, do it! I had a chain lift break a chain...with a car on it. Scared the beejeezus out of us. All I can say is thank God for safety locks! A wise word of caution is to also NEVER use the pump to hold a car up...rest it on the stops and you'll avoid a lot of unnecessary wear and tear.
Haven't had anyone come out in favor of the Rotary so far, does anyone here own one? I am about 95% sure that I'll be getting the Mohawk, it isn't every day that I get to buy something made in this country plus I just like how heavy duty they are. I did a search on the 646 chain they use, it has a strength of 27,000-29,000 lbs depending on manufacturer & I'm sure given the way the rest of it is built that it is the latter so 54,000-58,000 lbs chain capacity on a 10,000 lb lift is a good safety margin. Everyone on this and another forum have had nothing but positive things to say about the Mohawk & I suspect that it will be like the Eaton compressor in that once I have it the price will be forgotten but the enjoyment will be there each time I use it.
Lifts
Steve,
I sell automotive equipment, the domestically built Rotary is a fine lift, pretty much the standard for New Car Dealerships and it will serve you well. The Mohawk is in a class by itself. If you can afford the initial investment it will probably outlast you with regular maintenance. Avoid the off shore lifts at any cost, they are far better than they were even 2-3 years ago but the quality is still very hit or miss depending on the manufacturer of the day. |
Main thing to do now is secure funding for the project & once Uncle Sam makes his contribution look at ordering one |
Make sure which ever lift you buy it's installed correctly in the correct amount of high quality concrete. I have a symmetrical Mohawk lift and work on front wheel drive cars all the time. I ju
It will be, the nice thing about my barn is that it was built by a guy who owned a cement business & was made to work on cement trucks in. He said that when he was pouring the floor that whatever was left on the trucks at the end of the day went into the floor & that it is 18" thick in parts of the back half & the front half which is where the lift will go is at least 6"+.
Lifts
Remember that in a busy dealership the duty cycle on a lift is tremendous. 10 years is very doable for a name brand lift even at a high volume dealership that has regular maintenance performed. The Rotary in your situation would probably last MUCH longer than that, the biggest enemy would probably be not enough use. But if it's a dry environment and you perform regular maintenance the only advantage to the Mohawk would be your grandchildren could use it. The 10,000 pound capacity asymetrical Rotary is probably the best selling lift at the Dealer level.
Steve,
I have a Rotary 10k lift with Inbay and extended height options that I purchased two years ago. I shopped automotive lifts extensively before making my purchase and admired Mohawk lifts. A Mohawk lift is way more robust than my Rotary lift but because of unbudgeted expenses (I had to dig up and replace my concrete floor), I couldn't afford a Mohawk. It would have taken me another year to save up the extra money and I didn't want to wait that long. Having any decent lift will make you wonder how you lived without one! I will say this about my Rotary lift, though Mohawk may offer the same features - since I have a 12' ceiling I'm glad I got the extra lift height and Inbay is worth every penny. The Inbay feature moves the motor and pump up high on the lift post giving you more working room around the lift and even better, it puts a contoller on each post! Every person that has experience with other lifts and then used mine (when you have a lift, you suddenly have more friends) has commented on how convenient this feature is. Hope this helps. Doug |
I am really looking forward to getting it
In the last year I have replaced the exhausts on 2 cars & brake lines on 3 with the front end on car ramps & the back on jackstands, if/when this has to be done again it will be much nicer to do on a lift. Only purchase I've made that will be of questionable use is the dogbone creeper that I bought when I was planning on getting a kwiklift but I'll find some use for it. How wide is yours between the posts? I was looking at where I want to put it and found the floor was poured in a 145" slab there so I have 2 choices: 1. move posts 7" closer together to maintain 6" clearance from the expansion joints giving me 9' 5" between the posts or 2. move posts over so that each post is on a different slab. Which option is better? I'm thinking it would be better to keep both posts on the same slab for leveling purposes and to keep them from moving differently. Will moving the posts in 7" and having 9' 5" between the posts make that much difference over the standard 10' spacing? What do you guys think?
Steve,
Exhaust systems will no longer the Pain they once were when your lift is installed. You mentioned in an earlier post a Suburban. You should consult with your installer but I like the posts to be as wide as they can safely be. I don't know why being on two slabs would matter but I can say this - even though my posts are rotated, my Astro cargo vans are still a tight fit when exiting the vehicle. About the installation - my floor had a slight pitch because it was once used as a wash bay for school buses. I didn't think much about it. When the installers came, they looked at the floor and said "Not level. Sorry." I had to dig up 12" of concrete and I wasn't too happy about it. But whenever I have something heavy on the lift, I realize the installers were right and I'm glad they insisted my floor be absolutely level. Before I bought my lift, I assembled a four post Back Yard Buddy for my neighbor. I wouldn't even think about installing a two post lift myself. |
| Recent Garage - Tools posts with photos |
| America's Pride Lift Ampro, whole sad story [long] | kgus | Garage - Tools | 106 | 04-13-2009 05:59 AM |
| 350 Build.. Im sure there are plenty of threads on this... but this is specific!! | artillerystevens | Engine | 10 | 12-04-2006 09:34 PM |
| Lift Kit | CustomFord | Suspension - Brakes - Steering | 1 | 05-09-2006 03:21 PM |
| 4 post lifts | Beenaway2long | Garage - Tools | 11 | 01-28-2004 06:38 AM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
