Moisture in my garage - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 02:39 PM
ss396si's Avatar
Woulld it be a good idea to put a dehumidifier in my 1 car garage? I have a golden rod already underneath my car.
thanks
Old 07-14-2008, 04:13 PM
How air tight is your garage. With roof vents and doors that don't seal, letting in water laden air, it might be a up hill battle.
But the dehumidifyer is better than using a golden rod. All the golden rod is doing is heating the surrounding air so it will carry less water. The dehumidifyer will remove water from the air and circulate air through the garage. Just don't be opening and closing the doors too many times. TF
Old 07-14-2008, 05:12 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
A small window unit air conditioner would also do the trick. It would cool things off and you would not have to fool with emptying that water dish thing.
Old 07-14-2008, 05:28 PM
I got to agree with WB a window air conditioner would work wonders, it sure did for me.
Old 07-14-2008, 05:41 PM
Great idea the only drawback is the A/C unit is controled by temperature and the dehumidifyer has a humidistat to control the on/off cycles. But when it hot and humid during the summer just crank it up and wax the car with some liquid refreshment to offset the dry enviroment. TF
Old 07-14-2008, 06:22 PM
ss396si's Avatar
The garage has no windows, I just resealed the door(some light shining threw). I think the dehumidifier might be good added protection.What size do i need?
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
Painting in your Garage Centerline Body - Exterior 22 08-31-2007 10:23 AM
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
