Moisture Traps - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2009, 08:09 AM
MI2600's Avatar
Member# 3287
Moisture Traps
This may have been asked before, but I couldn't find it.
The question arose about the foil style sound deadener/insulation. Is this stuff a moisture trap? I'm especially concerned about inside doors which are exposed to direct rain/moisture.
I'm interested in learning anyone's long-term experience with this stuff.
Old 06-24-2009, 09:41 AM
Last journal entry: 50 Ply wagon
I just got done doing the roof panel and inside door panels with Hushmat. The stuff is heavy and not thick as the foam stuff is. Hushmat sticks to anything and really deadened the sound inside.
The stuff you are talking about is probably the aluminum foil on one or both sides. That stuff works well, but you want the closed cell foam. It won't trap water or absorb it. The downside with that stuff is getting it stuck down. You have to use the spray glue and wait for it to tack up.
Old 06-24-2009, 10:31 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You probably don't want to use the lightweight air filled stuff (if that's what you're talking about) inside the doors. Dynamat, Hushmat, Fatmat, etc. would be a better choice and easier to apply.
Do you wet the floor before painting? TurboFord Body - Exterior 110 05-02-2010 09:50 PM
Tail pipe moisture sanman Engine 20 03-13-2008 06:36 PM
water and moisture in air Lynch Garage - Tools 7 11-13-2007 09:16 AM
Moisture in oil breather western star Engine 7 12-31-2004 05:30 PM
Heat, Cold & Moisture rick1956 Garage - Tools 2 11-13-2004 01:55 PM
