Mold On or Bolt On Side Scoops? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2007, 03:43 PM
SHIFTY101EASY's Avatar
Last journal entry: Stripping Paint + Buying New Metal
what is a better choice???
http://cgi.ebay.com/ebaymotors/side-...mZ300111071482
i want to pull the trigger on those right now but don't know much about molding stuff on...do i just use some kitty hair or something?
this is for a 68 mustang....
Old 05-13-2007, 05:44 PM
bolt on scoops
i have a 68 mustang fastback. i bought the same scoops from the same people, very well mades, i had to do some sanding to match to the body. I also bought some roof side scoops from another person on ebay, they were paper thin, they were elinor scoops for molding, i decided to thicken the uppers with more glass and glassed in wood to hold bolt fastners. I will seam seal the scoops to the body along with using the fastners. I have never saw fiberglass stick to metal very long wthout cracking. I am not trying to make them look molded in, but I believe it will still make a statement.
Old 05-13-2007, 05:48 PM
so those side scoops in the link ARE in fact mold on ones, theres no bolt correct?? i wonder if i could add a bolt with some kitty hair and a threaded rod coming out of it....its how my quarter panel extensions are made....
Old 05-13-2007, 08:56 PM
Last journal entry: Timepiece - Design in Blue
Neither Kitty Hair, fiberglass resin, or body filler will properly bond a fiberglass scoop to metal. Even if you leave the bolts in, it's going to crack along the seams, nine times out of ten.
I use two-part epoxy structural type adhesives. With proper surface prep, and the correct adhesive, you have to use a grinder to remove the fiberglass part! It is permanently bonded.
I don't have the time right now to look through my suppliers and add links, but I'll try to get them posted here as soon as I can.
Old 05-13-2007, 09:07 PM
302 Z28's Avatar
Evercoat Vette panel adhesive.
Vince
Old 05-13-2007, 09:33 PM
sweet. okay i will look into that stuff...the guy selling the scoops just responded back and said they could come WITH bolt or without so i figured might as well come with bolts and i could probably also use the panel adhesive if it comes to that.....
Mold making questions ChrisMiddleron Body - Exterior 14 10-07-2008 03:03 AM
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 07:27 AM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 02:05 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 04:52 PM
