We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 01-15-2004, 07:25 AM
juveteach's Avatar
juveteach juveteach is offline
BUILD IT RIGHT, TWIST IT TIGHT !!!
Mold On Interior Panels
I recently purchased a 72 GTO that has been sitting in a garage closed up for the past 15+ years. My question, is there a good way to clean the interior panels without damage and make sure all the mold is gone for good. Every panel in it to include the headliner has it.
Thanks
Mike
Old 01-15-2004, 11:37 AM
Hot Rod Up Hot Rod Up is offline
Custom User Text:
Try some Spray Nine
Old 01-21-2004, 05:04 AM
mikeweyman's Avatar
mikeweyman mikeweyman is offline
you may need to use bleach if the stains don't come out, great for white,dunno about other colors, you may end up dyeing it.
Old 01-21-2004, 09:31 AM
Thom Laybourne's Avatar
Thom Laybourne Thom Laybourne is offline
NO BLEACH
I would not use bleach on anything. Navy Whites, maybe. I like to use OxyClean. Get a spray bottle and mix per directions. Spray area and use SOFT tooth brush on hard areas. Mildew will be easier to remove if the panel is removed / cleaned / dry in bright shade. The tough one is the head liner. I would spring for the bucks and have a shop remove and clean it. Most cars have a felt under the headliner. The mildew will leach back if not cleaned from the felt.
hr41pearl
Old 07-13-2004, 09:02 PM
Mr.Upholster Mr.Upholster is offline
New Member
old Plastic
Yea, only way to kill mold is with bleach....might want to add some water at first......Chances are that the plastic is dried out and all that wiping will blow away that grain and you will be up the creek with out a paddle.....You could get some vinyl paint and add a texture additive to it and re shoot it all...But you can't spray on dead plastic....it would have to be all sanded down to the healthy plastic before you could shoot it.....Don't forget to use plastic prep before you shoot it and a cross linking additive ...adhesive promoter.....see my site ***
Old 07-13-2004, 10:48 PM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
A commercial??
And Sway got spanked over a magazine.
Troy__________________
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 07-14-2004, 07:11 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
DO NOT use straight bleach. Add a little to water and try it. You don't want to add much more than what is added to the water to do laundry. read the instructions on the back of the jug first. Bleach will kill the mold but if used in the wrong strength will also bleach out any cloth that you have around. I would use something like simple green or something to that effect.
Kevin
Old 07-14-2004, 09:04 AM
troy-curt's Avatar
409 works good.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
