Are these skirts permanent? If they are and you want to bond fiberglass to metal, then yes 3M's 8115 will work...Just be sure to finish your lap area with fine paper (I finish mine in 320 before priming) and allow plenty of cure time for the panel bonding adhesive...give it extra cure time...if not, I've seen the bond line come back and be quite visible in time after it's painted
