Molding plastic parts to metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2004, 06:17 PM
I have a 1980 Trans Am and what I want to do is mold the back spoiler, which is plastic and mold the bottom fender flairs (rubber) flush with the car. I have seen it done and it looks sharp. My question is what should I use that will bond to both metal and rubber. The rubber fender flairs bolt on and the edge that runs along the quarter panel I plan to pop rivet then apply something over. I am afraid to use bondo or will it be OK. Something else I thought was lay a strip of fiberglass over the seem to add strenght. What do you think?
Thanks
Luke
Old 03-01-2004, 09:46 AM
astroracer's Avatar
Don't do it... Metal and fiberglass have different expansion rates and the joint will fail in a short time. The urethane fender flares will be especially prone to flexing and cracking and there is no way to stabilize the joint because of this.
There are some urethane panel adhesives available that will glue the dissimilar materials together but I have no experience with blending them into a metal panel and how long the transition joint will last. My experience, everytime, has been bad when trying to mold dissimilar materials together. It will look good for a while then you will start to see the seam...
Mark
Old 03-01-2004, 10:26 AM
willys36@aol.com's Avatar
Wiki Edits: 21
http://hotrodders.com/showthread.php...***+steel+bond
Old 03-01-2004, 11:08 AM
Hoyt's Avatar
74 Nova SS
bonding
I just bought a rear bumper filler for my 74 Nova and other than the piece not fitting correctly, there was no way to attach the fiberglass piece to the rear of the car. I used the two part epoxy that you can buy at your local paint store, that is used to bond body parts together. I would suggest finding someone that has the equipment already because the gun that mixes the two tubes together is very expensive. I got lucky and the guy doing my painting had what I needed to attach the piece to the car. I'm hoping not to have any problems with doing this, the mixture dries like a hard rubber. It's flexible so I'm thinking that it won't fail with the difference of expansion, time will tell. This stuff wouldn't be good for making the part look seamless though I don't believe, but if bonds like you would not believe.
Old 03-01-2004, 12:06 PM
Wiki Edits: 21
No problem gluing parts to the car like you did Hoyt, as long as there is a margin seam. The problem arises when one tries to get the seamless look 'cause there is just enough movement in the margin to crack paint and filler if it is a rigid variety.
Old 03-01-2004, 12:13 PM
Hoyt's Avatar
74 Nova SS
rigid
I agree Willy, I don't know how workable this epoxy is as far as sanding goes but I see it a lot in truck beds so I know that you can paint it with no problems. But you would never get the seamless look from if I don't think. I'd probably just use body filler and hope it lasts until I'm ready for a new paint job. Otherwise someone has some metal fabrication work to do.
Old 03-03-2004, 12:51 AM
Hot Rod Hellion's Avatar
I once bought a 73 camaro where the previous owner did just that. The three piece duck tail spoiler was molded in. And the filler had cracked down the whole length of it.
There might be better products or better workmanship out there, but I would be afraid anyway.
also, the corner pieces of the spoiler are not hard fiberglass on the trans ams like they are on the camaros. They are urethane rubber.
Urethane parts require a flexable additive be added to the paint to prevent spiderweb cracking of the topcoat.
