molds - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 04:29 AM
molds
how do i make molds, mold release (what is it) i tryed google and couldnt find anything on the subject.what i m trying to do is make a new lid for this casket i should have gotten the split one so the lid opens on either end . so i want to make a fiberglass top cut in half so the back section can open up. so what products do i need cant be to much of a job to do just need to be pointed in the right direction.
Old 01-22-2012, 08:18 AM
TucsonJay's Avatar
Check locally for a fiberglass materials provider. If they are a well-established and experienced business, they can tell you exactly what you need, and how to use it.
Old 01-22-2012, 09:02 AM
Some guidance, photos and information is also found at http://www.fiberglassforums.com/
Old 01-22-2012, 06:15 PM
Good old Johnson's Paste Wax is an excellent mold release for fiberglass mold making. I was taught to wax the surface thoroughly, five times. Spray on gel-coat, then lay up enough glass to be rigid. For a one off, 3-4 layers of 1 1/2 oz matt should be enough. A production mold should be much thicker. And it would need extra bracing.
Using this method yields an exact reverse copy of the surface. I tested it once on a door window. The brand and identification etching was perfectly visible in the gel-coat when it was removed.
If you're afraid of trusting just the wax, you can mist on a coat of PVA- Poly-Vinyl-Alcohol. PVA is a water soluable release agent.
This process can be done without gel-coat, by using straight resin. I think the gel-coat is worth the trouble.
I used to manufacture Corvette parts using Feather-Fil as the gel-coat. That made it easier to block sand before painting.
Old 01-22-2012, 06:41 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
wayneooo...I sent you a PM.... You can also look in my journal I show how I made some fenders from scratch... Use mold release wax...
Old 01-22-2012, 07:09 PM
You can also use what is called PVA mold release... It work's real well also..
Old 01-26-2012, 01:34 PM
check out you tube
Homemade fiberglass molds? polkat Body - Exterior 4 02-07-2011 08:50 AM
Plastic (OMG) molds GalaxieRoller Body - Exterior 4 03-26-2007 12:03 PM
molds? ProjectSuperNova Interior 7 10-13-2004 08:56 PM
