Moly Rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2008, 02:19 PM
Moly Rings
I have heard that you have to use a certain hone finish to get moly rings to seat properly? Is this true and if so, what do you have to use?
Old 01-16-2008, 03:20 PM
DoubleVision's Avatar
Use whatever the ring manufacter recommends, as they always have a different recommended finish. I've used them and honed the block with a basic hand hone and didn't have any issues, however, the rings will seat better and last longer with the correct finish.
Old 01-16-2008, 04:08 PM
If yoour not plate honing the ring really never break in
Old 01-16-2008, 05:30 PM
Moly rings take a smooth hone, 600 or 800 grit. Chrome rings like a rougher hone 400 grit or a bit less.
Bogie
Old 01-16-2008, 05:39 PM
What about crosshatching? Just run it through a couple of times real quick?
Old 01-16-2008, 09:32 PM
Bogie
Never heard of 800 grit at our shop cast rings require a 220 finish and moly rings require 280 with a 600 plateau or 400 plateau.
moly rings vs standard BillyBanana Engine 73 05-23-2015 04:53 PM
special hone for moly rings? VEGA 3503508.5 Engine 6 05-20-2006 10:10 AM
Need More Info On Piston Rings Canadian Charlie Engine 1 02-25-2006 05:00 PM
About how long do Moly rings take to seat? Malibu73 Engine 11 01-02-2006 01:53 PM
plasma moly rings seating period. TVR383 Engine 9 07-22-2005 04:39 PM
