Momentary Ground switch Questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2012, 03:44 PM
More skid steer wiring questions. However the new hollands I was working on before all got traded for 3 brand new CAT's so things are different in a good way most of the time. Their quality is great, and every wire is numbered and colored the same throughout with a second set of numbers coressponding to its location. The downside is that everything is sealed so good and wrapped in armor, that it makes it hard to modify.
Anyways , these skid steers all have two speed's and we do not want certain workers to be able to use the second speed (12mph versus 7mph) due to the amount they can already ruin in the first speed. However when we get in it, or when our other more cautious and caring help gets in, we want the two speed. We wouldn't have got the two speed to begin with but we would have had to special order them without and it would hurt the resale value more than what the option costs.
I initially was going to hide a very small rocker switch (those little dime sized ones) that would interrupt the two speed signal, but interrupting that caused the two speed indicator light to blink constantly as it sensed there was a fault. I then decided to try and interrupt the switch itself.
After some testing or wires and playing around what I found was that the two speed switch is fed 9-10volts (seemed odd, never got a real steady reading though), with the other side of the switch going to ground. I cannot physically get inside to see the wires at the switch as it is a sealed joystick that it is mounted in. The switch is a momentary switch.
As I have stated before, my knowledge of electrical concepts is not good at all, but my uneducated guess is that the computer is basically switching back and forth between low and high range simply based on how many times the switch is hit. I decided to interrupt the ground signal with the rocker switch, however the issue with this is that with the switch having to be hidden it will be very inconvenient to have to turn on and off every time we need to use it. I then moved onto plan two.
There are 4 additional switches (5v signal, intermittent ground) on the same joystick. One controls the horn, one locks in the auxiliary hydraulics for continuous flow and the other two are for controlling different electrical functions for attachments that require the use. The machine does not have the harness for running the attachments, but the joysticks are pre-wired. we will not be using the other two buttons on these machines so I thought, what if I tie into one of them as they are also momentary ground switches and essentially turned it into a sequence of having to push and hold one of them while simultaneously hitting the two speed switch.
At the end of all of this I think I answered my own question and figured it out. initially I was thinking I was going to have to use relays, but now realized all I need to do is connect the ground wire from the two speed switch to what would be the 5v signal wire and leave the ground side of that switch intact how it is, blocking the two speed trigger from grounding unless the other switch is pushed at the same time.
Correct me If I am wrong, but I am going to go try this now.
Thanks.
Old 04-16-2012, 04:55 PM
EOD Guy's Avatar
Why not contact CAT and see if the computer can be programed to do what you want?
Old 04-16-2012, 05:24 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Just thinking out loud here-I believe the signal you want to interrupt would be after the Auxilary Hydraulic ECM, which controls the Spool to allow the Hydraulic Flow to the 2 Speed-at least that's how I'd do it if it's a "B" Series Skid Steer-
Here's a overview of that circuit (look at page 80-82)-hope this helps-
faculty.riohondo.edu/.../BC%20CAT%20BOOK/SERV1783_TXT_...
or, try this one:
/url?sa=t&rct=j&q=2%20speed%20lockout%20cat%20skid% 20steers&source=web&cd=10&ved=0CJEBEBYwCQ&url=http %3A%2F%2Ffaculty.riohondo.edu%2Fjfrala%2FBC%2520CA T%2520BOOK%2FSERV1783_TXT_allBskidsteer.pdf&ei=hpm MT-2bM4n88gTipbi-CQ&usg=AFQjCNHj1R0ELUObyFDemRPgFGYTYkm0nw
Old 04-19-2012, 07:37 PM
your links didnt work for me sorry.
Why Neg. Ground vs. Pos. Ground? Joe G Electrical 26 10-21-2014 08:41 PM
Ground strap or ground wire? impalaman63 Electrical 12 07-20-2011 02:00 AM
6v positive ground to 12v negitive ground darksidecustoms Electrical 3 07-20-2009 09:29 PM
Fan Switch on the Ground Leg? JohnTN Electrical 8 05-15-2005 09:35 AM
what causes momentary stalling, low idle catscan4free Engine 0 02-23-2004 10:46 PM
