Mono leaf spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2009, 11:46 AM
moontanker's Avatar
Last journal entry: My 32 Ford pikup..
Mono leaf spring
Ive started the chassis on my 26 T coupe and I been busy .Looking around I spotteda mono cross spring,Anybody know about these for solid axel?
Old 02-22-2009, 10:05 AM
Irelands child's Avatar
The Durant mono leaf springs have worked well for me - but they don't give you enough shims to set the ride height as well as you might need. Not a problem to cut more out of plate stock though. You will need to know which way the end eyes roll and know what length spring hangers you have or will need to order. Also - Corvettes have had them for many years.
Dave W
Irelands child
Old 02-22-2009, 11:19 AM
kleen56's Avatar
We just installed a set in my buddys 28 T. The install was straight forward but the ride was stiff. The 28 already hit bumps and potholes badly with the leafs, but now with the monoleaf, you need a kidney belt. Not sure if a 28T will fit on your 26T, but he might sell you his cheap. I believe he's going back to the leafs.
Old 02-22-2009, 11:45 AM
That surprises me - mine did exactly the opposite. You might suggest that he might want to check his shocks. Also, a couple of write ups in a couple of rod mags were positive in the ride change which is why I did mine.
Dave W
Irelands child
Old 02-22-2009, 12:06 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
A lot of times a poor ride and handling is due to poor shock selection..Wish I could find another solution..(read cheaper) but it seems that what works is getting the good shocks from Koni or pro or something similar that can be rebuilt and revalved in the field in order to get the valving of the shock correct..a bit of overkill for some I know but that does work..
Sam
Old 02-22-2009, 01:25 PM
moontanker's Avatar
spring
Thanx guys ,I think Ill st ick to the old ways.I know posie well enough to know that the guys in the back could help me out.
Old 02-22-2009, 01:53 PM
Sam
Absolutely need good shocks. My truck, an Ford F350 FX4 Off Road package had Rancho branded as OEM. JUNK. It now has Bilsteins and I can actually keep it in a straight line instead of wondering in which lane that bump was going to set me down
Dave W
Irelands child
71 Nova mono to multi leaf question. 1971 Nova Suspension - Brakes - Steering 5 12-05-2008 10:11 PM
Flipping leaf spring cboy Suspension - Brakes - Steering 16 03-05-2007 04:53 PM
Leaf Spring Data base nautius Suspension - Brakes - Steering 8 11-05-2006 11:25 AM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
composit mono leaf spring?? sune Suspension - Brakes - Steering 2 05-05-2004 04:53 AM
