Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MOnte carlo 79 rear end?
Old 11-17-2007, 12:54 AM
DHMag's Avatar
DHMag DHMag is offline
quickest way is to check the code on the axle tube. or pull the diff cover off and read the pinion gear, it will have tooth counts on it for both the ring and pinion. ex: 41 ring gear teeth/17 pinion gear teeth = 2.41 ratio
