Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MOnte carlo 79 rear end?
Old 11-17-2007, 03:11 PM
schnitz's Avatar
schnitz schnitz is offline
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Originally Posted by DHMag
quickest way is to check the code on the axle tube. or pull the diff cover off and read the pinion gear, it will have tooth counts on it for both the ring and pinion. ex: 41 ring gear teeth/17 pinion gear teeth = 2.41 ratio
Not if you live in the salt /rust belt LOL! I've only once been able to find the axle code on anything that old (or older and sometimes even newer) that was just covered in rust. But, I do like the idea of pulling the cover and counting the number of teeth. That also gives you an excuse to change the differential's gear lube.
In a while, Chet.
