Monte Carlo Engine Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2003, 08:03 PM
Dans83Olds's Avatar
Sucking Gas & Haulin' *****
I am swaping a 350/th350 into a 1985 monte carlo with a 3.8V6 in it. I am using a 1983 cutlass as a donar car(radiator, cross member, motor mounts). The cutlass had a chevy 350 in it. Do i need to take the engine mounts off the frame of the cutlass and swap them to the monte? If so how do I get the darn things off. The have nuts on the back sides of the bolts, but can't find a place to put a open end wrench in to get them out. THanks.
Old 10-15-2003, 08:12 PM
Thumbs up motor swap
hey dans olds, i did basicly same swap once.i used torch to cut bolts out,you do have to use v8 mounts,also had to swap to another set of bolt holes.good luck bobby
Old 10-15-2003, 09:29 PM
Dans83Olds's Avatar
Thanks, looks like ill be getting the angle grinder out tomorrow.
Old 10-16-2003, 01:44 AM
Nos's Avatar
Nos Nos is offline
dont forget transmission mounts too!
Nos
N|O|S
Old 10-16-2003, 12:24 PM
Dans83Olds's Avatar
Got the tranny mounts, thanks.
