Monte Carlo swaps
This is probably a dumb question but...
Will any of the front brake components from a 1979 Chevy Caprice swap onto a 1970 Monte Carlo? Specifically, I need... Power Booster and Master Cylinder Front Disc Spindles Calipers Rotors Metal brake lines If these pieces won't interchange, does anyone have any recommendations for getting these pieces out of the junkyard? Will any from the truck boneyard fit? The yards around me are all out of chevelle and monte carlo parts, so I'm going to have to make something else work. Any suggestions on replacing all those parts on the cheap would really help. Brado |
Any one know?
The B-body parts WILL NOT bolt in. However some people have swapped them in to get better braking. The easiest way is to get some custom upper control arms. The B-body spindles are about 2" taller than yours and have either 11" or 12" brakes on them.
Doing a search on hear for "b-body" AND brakes will turn up a lot of info. |
Thanks Triaged, I appreciate the info. I've just got to find the most cost effective way to get this car on the road with my limited mech skills, and no fabrication skill. It's going to be fun...
Brado |
Spindles and rotors from a pre-'73 A-body (Chevelle & clones), '68-'74 X-body (Nova & clones), or '67-'69 Camaro/Firebird are the same as MC parts. A-body calipers & steering arms are the same, although steering arm lengths vary (be sure left & right are the same length, shorter gives quicker steering).
Drum spindles can be machined to work with disc brakes if you can't find what you need. www.nnnova.com sells them on an exchange basis. |
Go to an on-line parts store. Start comparing part numbers from Camaros to Caprices. If the wheel bearing numbers are all the same the rotors will swap. As far as I know the "B" body, "X" body and "F" body cars all used (basically) the same rotor bearings so most any 12" rotor can be swapped to another spindle with a change in the caliper also. 1LE camaros came with 12" rotors so that may be an option for the calipers...
The only real issue with this swap is bolt circle size. The big bodied cars used a 5 on 5 pattern where as the intermediates and pony cars used 5 on 4 3/4. A good brake shop could probably re-drill them for you if it comes down to that. Mark |
The B-body spindles into an A-body car is a pretty common junkyard swap, but as has been pointed out, its not a bolt in. The benefits are that you can find 12" brake spindles easier and the spindle is taller which dramatically improves suspension geometry. The downsides are that you need a custom upper control arm like one from Hotchkis or Global west. The other downside is that the B-body spindle sticks out a touch more. Its not enough to cause trouble with the tires rubbing, but it looks a bit funny. The solution is to use wheels from a third-gen F-body. They have staggered offsets front and rear. You can use the more positive offset wheels in the front and the more negative in the back. I did that with an 87 Cutlass and used GTA basketweave wheels. Looked nice
![]() Once you switch to the B-body spindles, you'll need to either redrill the rotors for the smaller A/G/F pattern, or purchase F-body rotors which will fit on the spindle using the same bearings. Double check bearing part numbers for the application since I'm not sure all years are the same. Others have outlined the X or A spindle swap which is just fine and a complete bolt-in, but the B swap get get you cheap 12" and better geometry. Up to you |
After about 1975 GM ball joints used a different taper too. Make sure you use ball joints which fit the spindle correctly if you do the B-body swap, or you might snap one. I have also read that this swap reduces the turning radius.
Thanks guys, you all rock. That's why I love this site
What I've decided to do is machine the drum spindle down and get all new gear from the local parts store. A little background on this, all 1970 Monte Carlos are supposed to have power front discs, but someone raped it before the guy we got it from got it. But they went through the trouble of putting drum pieces on and hooking the master back up, minus the booster. So I now have to get all the stuff back on it before I'm putting my kids in the backseat on cruise night. I'm going to rebuild the whole steering and suspension system (my first time ever messing with this stuff, wish me luck). I might need to get new caliper brackets too, not sure where to get those at. But be sure I'll be on here screamin' for help sooner or later
| '06 Monte Carlo | schnitz | Hotrodders' Lounge | 31 | 01-15-2005 11:38 PM |
| Bring Back the RWD V8 Monte Carlo!! | Fragzem | Hotrodders' Lounge | 18 | 10-16-2004 11:35 PM |
| Does anybody own 84-88 monte carlo? | 87442lover | Engine | 5 | 01-27-2004 10:18 PM |
| Monte Carlo rear disc brakes question... ? | berkelusa | Suspension - Brakes - Steering | 2 | 09-29-2003 08:57 AM |
