-   -   monte carlo tilt front (http://www.hotrodders.com/forum/monte-carlo-tilt-front-122789.html)
F3RR3T 08-22-2007 02:37 PM
I want to tilt the front clip on my 86 Monte Carlo luxury sport. the whole front end needs to come forward than tilt up. it will be all the original front clip except a fiberglass hood. i still want the hood to function.
the hardest part i believe will be keeping the inner fenders
engine will be a gm crate zz4 with efi and block huggers.
im more of a visual person so if you have pictures great if not i can follow along pretty good.
my fabrication skills are good i can well really well (with a torch and welding rod< forgot the technical name for it) im good at fiberglass and if i dont know how to do something i find out.
another question the front nose on the car is fiberglass and the fenders are metal so i quess there will be extensive bracing needed.
if i left out any info you need let me know
and post them g-body pics
F3RR3T 08-23-2007 01:39 AM
anyone?
sorry if i come of impatient just eager to learn and get started.
and do yall have hotrodders.com window banners
NEW INTERIORS 08-23-2007 10:01 AM
Making the front end tilt is not the hard part,Making the hood open is going to be the fun part.I have a pic of my 1957 chevy i made tilt,In my album,Look at everything good before you start cutting. :thumbup: :thumbup:
F3RR3T 08-23-2007 12:11 PM
how hard is it to keep the inner fenders. i got to looking at it real close. man its going to be a frickin pain to do. maybe ill just spent the time shaving the firewall. and clean up the engine bay
NEW INTERIORS 08-23-2007 01:28 PM
2 Attachment(s)
When i did my 57 i didn't want inner fenders.I bolted the hood to the fenders ,In put spacer between the hood in fenders,To get the right gap.I was able to tilt the front end off the bumper brackets,On a 57 it is real easy to do.Then you have to cut the back half of the fenders,In weld new lips on them.You can do it without cutting the fenders,But you will need two people to tilt the front end everytime you want to open the front end.The fenders will hit the doors,An mess up a nice paint job,You can leave the inner fenders, But you will have to cut them alittle,Plus you will have to get every thing off of them.Hope this helps.I put these pics.the 32 chevy i hand built that hole car.The 57 pic will show you the bottom of the fender i was talking about. :thumbup: :thumbup:
