Moog K6218 control arm shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2010, 08:16 PM
Hello fellow gear heads. I am rebuilding the front end on my 1987 Turbo Regal. Should I use these off-set control arm shafts? Mine are shot. They are suppose to provide more positive camber. What do you guys think? Thanks for any input.
Old 12-26-2010, 07:28 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I have had a couple of G-body GM's, I cant see the need for positive camber unless you run the front end higher than stock and have to compensate for negative camber. I liked slightly negative on mine.
Old 12-26-2010, 09:26 AM
Z27LS3's Avatar
I dont think the '87 would be needing that change. It drives, steers OK? tires wear OK? if yes, dont do it. Unless there is a specific reason you wanted them I vote NO.
Moog P/N catalog? BMM Suspension - Brakes - Steering 5 02-09-2011 11:32 AM
upper control arm shaft montea Suspension - Brakes - Steering 2 04-20-2007 03:15 PM
DANA or MOOG balljoints???? baddbob Suspension - Brakes - Steering 4 07-21-2006 11:24 PM
1958 Chevy-Upper Control Arm Cross Shaft-HELP!! snowjoe Suspension - Brakes - Steering 2 05-26-2006 03:28 PM
Moog catalog on the web?? 406chevelle Hotrodders' Lounge 2 04-20-2004 02:31 PM
