moonshine the new alternative fuel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2012, 02:12 PM
1996thunderchicken's Avatar
ALL AMERICAN MADE
Ok I have been pondering on this a while and really starting to think about trying to turn moonshine into a fuel source any ideas would be apreciated thanks in advance
Old 04-15-2012, 02:18 PM
35terraplane's Avatar
Moonshine
You didn't ponder long enough, or you should have been reading when you were pondering. Ethanol Is nothing but moonshine made from corn, they just put an additive in it so you can't drink it.
Bob
Old 04-15-2012, 03:59 PM
Last journal entry: My Last Hot Rod
make wood alchohol
its easier to make and produces more power than corn juice. Its called methanol it carries with it Oxygen molecules. We used in in our dirt cars. But you need the keep the carbs clean. make it from wood or paper. When you burn wood what you see in the flame is wood alcohol burning. I mad a quart last year maybe when i finish my Coupe ill make my own for the coupe.
Old 04-15-2012, 04:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The kicker is making enough alky (and for a cheaper price with all costs included) than you can buy fuel from the pump. Unless you have a virtually free and virtually unlimited supply of raw materials for making alky, this isn't going to happen. And once everyone tries to get on board, the free or cheap supplies of raw materials will either be divided into too small portions for it to work, or the price of those cheap raw materials will rise w/the demand for them.
Tried finding any "free" cooking oil lately to turn into diesel? Good luck w/that, anymore.
Old 04-15-2012, 07:32 PM
Ww2
The Germans and USA farmers made wood alcohol to run their tractors and machines.My Grandfather made it also..as late as the late 50's I remember. I can make enough for Use just for the Rod as it is not a daily driver or wont be. I wont have to worry about dipping into my regular cash for fun driving. I have a good supply of wood what I make will be for my use only not any one else. And yes the cost will rise as people get wise to this every crook and price gouger will come out of the wood work. But I can still make it cheaper than $4.00 a gallon easy by using wood as the cooking fuel.
Old 04-15-2012, 07:33 PM
ALL AMERICAN MADE
i know but if all of our oil companies want raise the prices to 5 bucks a gallon got to do something to scare the pants off of them do it till they get the message i am sick and tired of them being able to take advantage of us and able to take us hostage it is 100 percent bs
Old 04-15-2012, 07:40 PM
I agree lets hold their feet to the flame
. I heard US is exporting Gas for the 1st time since 1961 that means We are using less and its hurting the Big Companies so they are exporting the gas and oil to make up the difference, Keep the heat on these crooks
Old 04-15-2012, 07:52 PM
I thought it was a matter of supply and demand, Foreign countries are developing, and there is more demand for oil, so therefore the oil companies can jack the price.
Old 04-15-2012, 07:58 PM
supply and demand
almost bankrupt the USA its about time we all used less and done more for ourselves such as alternate fuels made at home...
Old 04-15-2012, 09:00 PM
If you think gas is too high look to Washington not the oil companies. They promised European style prices when they were running for election. We have plenty of green energy now, it's called natural gas.
Old 04-15-2012, 09:54 PM
Hot Rod Has Been
Moonshine IS E85... they beat ya to it!
Old 04-15-2012, 10:13 PM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
The bigger problem is what to do with what comes out of the still. Finding things to put in is easy, but if you dont have a feedlot or some livestock of some sort to eat the stillage, you will be up to your armpits quick. The nice thing is it can be something as simple as earthworm beds, or as complicated as cattle. My neighbors have chickens, and I also produce methane in a biogas digester and that helps run the stills.
I make ethanol for my cars, modify carbs (Qjets work damn nice) and build engines to run efficiently on ethanol. It has a bit of a learning curve but its worth the effort.
FYI methanol is not exactly easy to make, you need an acid bath to break down the cellulose and then lots of heat. Ethanol is much simpler, less toxic, and far less corrosive. I like methanol, but the requirements for it are spendy, and it takes quite a bit more to run an engine, then you need an after lube to keep everything from being eaten.
harness alternative dcousec Electrical 1 01-28-2012 03:21 PM
alternative fuel camaro jeff catlett Introduce Yourself 1 05-31-2006 11:47 PM
Alternative fuel or a bomb Gr8 '48 bow tie Hotrodders' Lounge 0 01-09-2006 11:21 PM
alternative interior? mdreamer Interior 0 11-25-2003 11:42 AM
Any Other Alternative 50chevdelux Suspension - Brakes - Steering 8 03-04-2003 11:38 AM
