mopar 318 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2013, 09:20 AM
mopar 318
I got a got a 91 dodge w-150 I put a comp cam in and a double roller timing set the only way I could get it to fire was at 12 and 12 on the new cam and crank gears but it seems to be out of time still what do I need to do to get it in time bein at 12 and 12.
Old 09-14-2013, 10:00 AM
Banned
first you need to verify TDC on 1 and make sure your distributor is not 180 out.
Old 09-14-2013, 10:10 AM
techinspector1's Avatar
Wiki Edits: 326
Start with a genuine factory service manual......
http://www.faxonautoliterature.com/1...al-P15871.aspx
Or a reprint of the original for a little less money....
http://www.faxonautoliterature.com/1...et-P25693.aspx
Old 09-14-2013, 10:14 AM
mopar 318
i took the plug out turned it over till it blew the air out of the plug hole then i put the balancer mark on the 0 degree mark which i didn't have to turn the crack much to do that and stuck a screwdriver in the plug hole and the pistons up i took the valve cover off and the rocker arms are both up and the rotor button is pointing towards the front of the motor but it wont start and backfires still im just not to sure on where to put the rotor button.
Old 09-14-2013, 10:24 AM
mopar 318
bein its 12 and 12 and not 12 and 6 do i need to put it on the #6 and rewire to fire #6 as the #1 cylinder and when i put the timing chain on i put it exactly 12 and 12 it was suppose to be advanced or anything is it.
Old 09-14-2013, 11:12 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
moving to basics forum. Please post tech questions in tech forums, not introduction forum
Old 09-14-2013, 11:55 AM
LATECH's Avatar
First thing you should do is STOP making DUPLICATE POSTS.
You will get better results keeping ONE post for the information you are looking for. And you will make my job easier.
Fact is stranger than Fiction
Old 09-14-2013, 05:27 PM
Wiki Edits: 326
Well, apparently the whole mess is the same as a SBC, as far as cylinder numbering, firing order and rotor direction. So, read this tutorial and you should be able to get the motor running.....
http://www.crankshaftcoalition.com/w...stment_SBC/BBC
You probably made the common mistake of trying to time the motor just after installing the cam at 6 and 12. The motor was on #6 TDC firing, not #1. You have to rotate the crank one full revolution to have the marks at 12 and 12 in order to have the #1 cylinder on the compression/firing stroke.
The Following User Says Thank You to techinspector1 For This Useful Post:
LATECH (09-14-2013)
Old 09-14-2013, 07:10 PM
mopar 318
yeah I tried and tried to do 6 and 12 after I put the new cam in but all it would do was backfire through the tbi so so I brought it back to tdc and noticed the cam was at 12 not 6 I took the distributor cap off and it was 180 off so I turned it around and it fired up so I put it back to together and started back up and it backfires if you get on the gas like its still off and it wont run unless its advanced all the way and it wont go when put into gear.
Old 09-14-2013, 07:13 PM
mopar 318
when its at tdc should the rotor button point at #1 before #1 after #1 im bout ready to tear back apart and try to 6 and 12 again.
Old 09-14-2013, 07:16 PM
Banned
ok what do you mean by turned it around? did you take the dizzy back out and start over?
Old 09-14-2013, 07:21 PM
mopar 318
when I brought it back to tdc with the cam and crank both at 12 when I took the distributor cap off the rotor button was pointing toward the fire wall so I turned it 180 and it pointed toward the front of the motor
Old 09-15-2013, 08:57 AM
Banned
i see , you must take the dizzy out, you can not just turn the rotor to where you want it. the gears need to line up. Here read this it should get you going.
How to Replace A Distributor Without Going Crazy
also here is a basic install video
https://www.youtube.com/watch?v=FjNS_PHTRog
Old 09-15-2013, 06:45 PM
mopar 318
i went out today and pulled the timing cover off I put it at 6 and 12 the piston was up and the rotor was 180 off so I turned it to line up with the #1 cylinder tried to start it and it backfired so I turned the crank you could feel it suck my finger kept turnin it till it blew my finger off lined the marks up and it was 12 and 12 again so I put the rotor on #1 wont start i lined them up again put it a tooth after #1 wouldn't start lined up again and put it a tooth b4 #1 and still wont start my 88 ramcharger when at tdc the rotor is after #1 my 91 wont run that way and thanks so far on all your help.
318 Mopar rebuild Schoust Engine 5 12-27-2011 07:46 AM
mopar 318, whats next? streetpirate Engine 3 08-24-2007 09:59 PM
318 mopar tad Engine 0 04-30-2004 02:33 PM
Mopar 273/318 street rodder 1937 Engine 8 04-28-2004 08:42 AM
318 mopar build-up tad Engine 7 10-01-2003 08:57 AM
