Mopar 318 transmission bolt pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2009, 06:05 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Does anyone know of a front wheel drive trans that will bolt up to a small block Mopar, looking at 318 or a 360
Standard would be the first choice but an auto would work if needed.
This will be a transverse install, mid engine placement.
The only way this will work is a direct bolt in as any adapter plate will move it too far to the right.
Thanks
Old 01-29-2009, 06:46 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
A Mopar factory FWD trans axle with the rear wheel drive engine bell pattern?
Never seen one.
Old 01-29-2009, 12:25 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
What does the first gen Intrepid/Eagle, etc have for a bolt pattern?
They were fwd with the engine sitting North/South though instead of transverse.
Old 01-29-2009, 07:14 PM
It needs to be a transverse for my application. If I was to do it the other way I would find a 500 Caddy front wheel drive
Old 01-29-2009, 10:56 PM
Wiki Edits: 85
Never have seen anything in the thousands of front wheel drive Chrysler transaxles I have owned.
Old 01-30-2009, 05:47 AM
Kind of figured that much.
Thanks for the imput.
Need Mopar 318 LA assembly tips. Hippie Engine 2 11-12-2007 04:44 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
bolt pattern 5 on: 5 1/2", 4 3/4", 4 1/2" bolt circles which is best? 37ford4dr Suspension - Brakes - Steering 21 01-05-2006 04:01 PM
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 02:02 PM
oil pan for 318 mopar oldnable Engine 1 08-22-2002 02:52 AM
