Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mopar 360 swap
Thread: Mopar 360 swap
Old 08-10-2010, 07:36 AM
345 desoto's Avatar
345 desoto 345 desoto is offline
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Try getting away with just an exhaust valve. Since it has no ridge on the cylinders, leave the rings/bearings as is...for now. If it starts/runs half way decent, you'll be fine. If not, then you might look into rings/bearings. If it ran fine before it dropped the valve piece, it should run fine with a new valve. Don't worry about the piston top...
