Mopar 360 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2010, 12:25 AM
Mopar 360 swap
Hey everyone, posting for my friend so bare with me. Alright, story starts off with a 360 magnum outa his dads '94 or 95 Dodge ram 1500. The engine randomly lost a cylinder and ran like CRAP. We ran a compression test and got spectacularly low readings. Anyways, we pulled the engine and replaced it. So now my friend and I have a FREE 360 and alot of times on our hands. The engine was in bad shape, burned/ leaked oil, dropped a cylinder, and had LOW compression. Although there are maybe 150,000 KM at most on it, they where pretty abusive LOL. Anyways, we pull the engine apart and find that the reason it dropped a cylinder was because a part of the exhaust valve broke off and jumped around in the bore for a bit After some close inspection it turns out it didn't even hurt the bore!!! All it did was pit the top of the piston a little, but not very much. Also, there is NO ridge what so ever.
Anyways, my friend and I are now going to take on a new project, reviving a '57 Dodge Fargo. Right now its sitting on the farm and has been sitting for at least the past 11 years. From what we where told it is supposed to have a straight 6 and a 3 on the tree. Our plan is to get the truck home, pull the engine and tranny, pack them away nice and easy in case we ever want to make her stock again, and drop the 360 in.
In the effort to do it the cheapest way passable I believe my friend wants to use the Auto tranny from the dodge ram. I know we will need to get a custom drive shaft but does anyone know if the mounts will work? I have a feeling the tranny mounts will need to be moved o fabed up.
As for the engine, we are going to pick up a rebuild kit from Summit and pretty much just re ring it. As for the piston I am pretty sure its alright, its just very slight pitting. Our plan for the heads where to go to a machine shop and see if they might have a extra valve we might be able to pick up, or maybe just head to the JY to see if we could just pull a set of heads. Anyways, we where just gunna clean the valve up and stick it in and re lap all the valves. As for the intake and Distributor we are going to use a '74 360 intake and pick up a new HEI from summit.
My friend and I really aren't looking for anything special or any sorda hot rod. The main goal is to have a running truck to haul stuff, and tow me home from the track when I break down LOL.
I know I wrote a whole lot but my friend wanted me to come ask some guys with more experience before he starts blowin cash. Thanks in advance everyone,
Adam
Old 08-10-2010, 04:53 AM
I'd try to spend as little as possible to get that engine running. Maybe you can get away with just replacing/lapping in a new valve, and a basic ring/bearing job. I'm not sure about Mopar intakes interchanging between 90's and 70's engines...I'm sure a bunch of guys here would know though. I'm pretty sure the mounts will have to be moved or fabricated. But hey...that's hotrodding. Post some pics. Sounds interesting. Good Luck!!
Old 08-10-2010, 06:36 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Try getting away with just an exhaust valve. Since it has no ridge on the cylinders, leave the rings/bearings as is...for now. If it starts/runs half way decent, you'll be fine. If not, then you might look into rings/bearings. If it ran fine before it dropped the valve piece, it should run fine with a new valve. Don't worry about the piston top...
Old 08-10-2010, 07:03 AM
sqzbox's Avatar
My pipes are my music
150,000 Km and no ridge? That's remarkable! Don't forget to find a radiator with tranny cooler for the auto trans.
Old 08-10-2010, 05:36 PM
Mopar or no car.
You'll need an eddelbrock or ebay carb intake if you plan to use a carb, magnums are different intake bolt pattern than LA small blocks, you'll need a 727 trans, or use the computer that controlls the newer trans and electric fuel pump too, magnums dont have a place for the mech fuel pump.
Mopar 360 "budget build"? hduff Engine 5 04-13-2010 12:56 AM
cams in relation to c.i. sexypizzaman Engine 19 11-05-2009 10:01 AM
48 dodge mopar big block swap 48wolf Engine 5 03-25-2008 11:11 PM
273 to 360 motor swap valiantmaster65 Engine 5 01-15-2008 11:34 AM
Swapping 273(or 318) to a 340/360 in Mopar A-body Gilligan Engine 7 09-18-2004 09:42 AM
