Mopar 400B Which is better 72 or 76?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2007, 09:16 PM
MOTOR HEAD's Avatar
Born to Wrench
Ok , here's the deal , I'm gonna stuff one of these 400B blocks in my 84 Dodge 4x4. One is a 1972 , the other is a 1976. Both are in great shape and would make a solid foundation to build on. (But) I have heard that (some) yrs of 400B (and also) 440RB are a little thinner than the others. I plan on building the 400B stroker that I've heard is a real power builder , just looking for some input from someone who has done one of these 400B strokers. Thanks!! Motorhead
Old 12-26-2007, 09:54 PM
SSedan64's Avatar
400b
I can't remember for sure but I'm thinking 71 or 72 had the thickest blocks. I have a 71 400B from a Chrysler Newport. CarCraft or HotRod Mag did a buildup of this engine using Chevy 454 rods, custom pistons & Mopar 440 crank with mains machined smaller. Came out to be 454c.i. Try searching one of their websites for the story. I like the 400B because of the bigger bore than the 440RB.
Old 12-26-2007, 09:59 PM
http://www.440source.com/blockinfo.htm
Good move.
a 3614230 (1972-73) 400 block. These are the thickest of any blocks around, bar none
440 Source has what you need.
Old 12-27-2007, 12:06 AM
charger528's Avatar
Last journal entry: 1991 Mustang LX Mopar powered Drag car
the 72 block is better you can go easily out to 512 with a 440 source kit
I just finished putting together a 528cid using one of thier kits the kit cost me under $2000 even with the rod option and computer balanceing if you want a closer look at the kit ck my threads.
I posted pics of the internals
posts
inside the beast 440 chrysler strocked to 528cid
Old 12-27-2007, 12:28 PM
MOTOR HEAD's Avatar
Born to Wrench
72 or 76 400B which is better?
Thanks for all the input guys , I really appreciate it. Now here is another question! I know that with just stock mopar stuff the interchange between the stock pieces can vary engine displacement upto 100 cubes or more.So, I'm wondering.... I have (stuffed in the corner) a 63 413RB , this encountered some cylinder issues and is pretty much done. But the bottom end is still A-1. I could put that crank in the 400B right fella's? , just have the mains turned down to 2.625-in. and use the 413RB rods.Just wanna try to use up some of this original stuff I have laying around. Also , the 413RB has #516 heads on it , these will probably be better than the 400B's #452..just have smaller cooling passages? Thanks again guys , I'm gonna goto 440 source now and look around!! Motorhead
AMC a Mopar? Stop the nonsense! SpiritRT Hotrodders' Lounge 19 09-12-2012 05:05 AM
72 camaro subframe in my 72 nova 396nova Suspension - Brakes - Steering 4 07-09-2011 05:58 AM
performer rpm or mopar perf 440 intake? TRLBLAZR60 Engine 35 11-10-2007 02:50 AM
trading a stripped 72 espirt for a 72 grandville legionlleh Off-Topic 3 02-10-2007 07:40 PM
*Help* 72 Chevy P/U with Step Side Box *Help* Mustangsaly General Rodding Tech 8 01-20-2006 09:07 PM
