Mopar 727 buildups. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 12:06 AM
Mopar 727 buildups.
Other then shift kits and deep pans, what mods have folks here done to their 727 trannys? I'm thinking in terms of extra clutches, servo mods, sprags, etc.
What have you all done?
Old 04-17-2006, 07:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Bolt in rear sparg helps these units.
Shift kits form TransGo work well.
Gettin extra frictions in these drums require machine work, it's easier sometimes to find higher count drum to use.
Shift timing is critical in a TF 3 speed for high perf shifts. Sometimes bleed holes are needed in a couple of spots to allow the low band to come off faster to avoid a tie up on the manual 1-2 shift.
Same applies on the 2-3 shift
727 Upgrade? polkat Transmission - Rearend 1 04-03-2006 09:43 PM
Mopar 727 subman17 Transmission - Rearend 1 09-09-2005 10:22 AM
727 Torqueflight Mopar transmission fluid mitmaks Transmission - Rearend 2 03-25-2005 06:50 PM
Mopar 727 and 904 lluciano77 Transmission - Rearend 6 02-17-2004 01:16 AM
MOPAR 440/ H/O & 727 trans 24,000 original miles fastco Engine 1 09-14-2002 04:23 PM
