mopar 8-1/4 ring and pinion pattern - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-05-2008, 06:13 PM
The shim under the race is a Chrysler/Dana thing, they set the PD on the D60s this way.
On the side bearing pre load it is kind of a feal for thing. I get the BL I am looking for and snug them up with a spanner wrench then torque the caps down then tighten the spanner nuts to about 20ft pounds. Remember that is going to keep the backlash where you set it. If they are to loose they will move under power.
Mike
  #17 (permalink)
Old 02-02-2009, 08:40 AM
Finally got her installed and running
Just an update, I finally got that rear installed in my 73 360 powered Duster. Things went well, no whining gear noises, these sound like they are going to work out just fine.
Here is a link to the intall I have posted on the abody site:
http://www.forabodiesonly.com/mopar/...ad.php?t=52969
Ring and pinion pattern Question blacklabzeke Transmission - Rearend 11 09-23-2007 08:15 PM
Problem setting up guts of ten bolt rwruther Transmission - Rearend 18 08-30-2007 11:07 PM
Ring & Pinion Tooth Contact Pattern GM 10-Bolt leejoy Transmission - Rearend 52 12-15-2006 07:26 PM
Ring & Pinion Setup - GM 10-Bolt Help leejoy Transmission - Rearend 3 11-21-2006 08:02 PM
GM 8.5" 10-bolt Ring & Pinion Swap leejoy Transmission - Rearend 21 08-29-2006 11:11 AM
