Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mopar 8-1/4 ring and pinion pattern
Old 07-17-2008, 06:00 AM
Goldduster360 Goldduster360 is offline
richmond patterns
I also found some nice examples of actual gear patterns instead of illustrated pictures like everyone always shows. I think my pattern falls in between the second and the last one shown. What do you think?
http://www.ricks2k.com/info/instruct...gandpinion.pdf
Also, my pattern seems to look close to the second and the last example shown here:
http://www.drivetrain.com/ringpinioninstal.html
You will notice it says to either decrease pinion depth as in example #2 or to increase backlash as in the last one. My contact is fairly centered though, they show them closer to the tow than mine. Thoughts? I am at a loss what move to make next. I am thinking go for maximum allowable backlash, it's at 10-11-1/2 depending on where I check it. I would imagine you can go a tad over max if it's within .002" in a couple spots.
Edited in:
And here is another pattern link, this guy went through about the same amount of effort as I did and his pattern ended up looking like mine. Maybe some are just not going to be perfect?
http://www.chevelles.com/forums/show...pinion+pattern
