MOPAR or CHEVY TRI-POWER - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 07:10 PM
crossfire84's Avatar
Tri-Powers are cool
OK i have a vette tri-power BBC intake i want to run. my question is will the Mopar Holley carbs be direct replacement . 1 will they bolt on my intake. 2 would the vette air cleaner drop on these? i know the linkage would have to modified. the reason for this is the Mopar carbs are cheaper. this is a street rod not a vette. thanks for your help.
Old 08-01-2006, 07:55 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
my memory fails me but here goes......... IF the original carbs were Rochesters then the answer is no because the hollies are bigger. have you eyeballed the hollies? It is very obvious, the hollies look like 1/2 of a quad right down to the fuel bowl
Old 08-01-2006, 08:23 PM
Mopar Or Chevy Tri-power
The '67 thru '69 Corvette big block Tri-powers used Holleys as did the big block Mopars. I have a '69 Tri-power Corvette and at one time used a Mopar center carb because it flows a little more air. The Holleys used on the Mopars will fit your Chevy manifold and the air cleaner will fit as on the original carbs. As you said, the linkage may take some work ... I may have used the base from the Corvette Holley on the Mopar Holley ... I do not remember for sure. How much do the Corvette Holleys cost these days?
Ford GT
Old 08-01-2006, 08:27 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Possible hijacking here
If you for some silly reason decide to not use that tri-power setup----
could always send it to me
It would look pretty cool in the 59----454ho crate
Bryan
Old 08-02-2006, 03:36 PM
Tri-Powers are cool
the vette carbs go for [0-3659 outboard carbs are $325 each]
the [0-4055-1 center is $475]
the mopars are $308 and $410 thanks for all the input every one.
Bbc Tri Power crossfire84 Engine 5 07-20-2012 02:21 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 10:50 AM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 11:15 AM
