Mopar crank shaft question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2012, 04:01 PM
I am new to the Mopar world and will need all the help I can get. I have a 413 engine with the long ram manifold that I will install in a 31 Plymouth 5 window coupe. My question is what do I have to get to ust the 833 4 speed trans? I am told that the crank needs to be machined to receive the pilot bushing, is this true?
Old 10-14-2012, 04:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders
This is the introduction forum, not for tech questions. Not many members read this section
I will move to Engine forum.
Old 10-14-2012, 04:20 PM
techinspector1's Avatar
Wiki Edits: 326
The factory installed this trans behind RB motors like yours, so yeah, the only thing you should have to do is drill the crank for a pilot bushing if it's not already drilled. Everything else should just bolt up. Personally, I'm a fan of bushings, not bearings. A bushing will still work when it's worn out. If a bearing goes bad, you have do get your tools out.
http://www.rockauto.com/catalog/x,ca...%2B413cid%2BV8
350 Crank Shaft Question EazyDuzIt102 Engine 4 08-30-2012 09:42 PM
crank shaft size. Ben.T Engine 1 05-09-2007 01:16 PM
Crank shaft worth 428ho Engine 2 05-04-2007 07:03 AM
Best way to store a crank shaft? 1931 steve General Rodding Tech 30 11-04-2006 07:38 PM
crank shaft Doug Renton Engine 2 10-01-2002 05:48 AM
