-   -   Mopar door hinge 'S' springs, same or different (http://www.hotrodders.com/forum/mopar-door-hinge-s-springs-same-different-186804.html)
B series 79 10-29-2010 09:33 PM
Came across an issue with my dd Shadow. Ended up borrowing a hinge from my donor stash to get the car back on the road but when doing some research I came across something even better I think. Something I hope that would allow me to rebuild all the hinges.
Heres the original torsion spring from my 94 shadow in all its worn out glory. Approximately 5" end to end.
http://i254.photobucket.com/albums/h...Picture067.jpg
Part on ebay
They sure look the same and knowing mopar little things like this stayed the same for years but before I start buying more stuff if someone with a B or E body or someone who just knows everything... Could verify the distance between the ends as being the same or not ?
Thanks
B series 79 11-03-2010 10:59 PM
Thought this might turn into a cricket chirp thread... They are not the same dimensions but very close, close enough to give it a go anyways.
