The front sway bars were on MOST RR's- but not all. The 318 cars were the most likely to not have the front bar installed.
This is a '72 RR w/the 440: Last edited by cobalt327; 04-11-2010 at 04:01 AM. |
I didn't know a 71 rr could come with a 318, I thought the 383 was the standard engine, and from there the only other engines available were the 440 magnum, 440+6, 426 hemi. I have never seen stock 71 rr lower control arms, this is my first rr, and I want to know if my control arms were taken off by the previous owner and replaced with satellite lower control arms. I see that there is a bracket welded onto each of my control arms, as seen in the pictures I posted, but are these brackets the correct brackets to hold the stock front sway bar? Are my control arms stock Roadrunner control arms or are they satellite?
I think my browser is acting up. My email is showing that there was a question about my vin number, but I dont see it showing up as a post or a private message. The question was, what was the first 5 of my vin. The first 5 Numbers are RM23N
Heres what i show you should have with these #s should be a #1 after the letter N showing that it's a 1971.JMO Body Type: R = Road Runner Price Class: M = Medium Body Type: 23 = 2 Door Hardtop Engine: N = 383 300HP 1-4BBL 8 CYL Year: 1 = 1971 Cole Last edited by eloc431962; 04-11-2010 at 10:22 AM. |
I suggest you ask your question at MOPARTS.COM. That site is probably the largest Mopar site on the net and there is no doubt the guys there will have the answer.
Centerline HotRodsAndHemis.com The most important things you learn are those things you learn AFTER you know it all. -- Chip Foose |
Yes i would check there also if i were you. I know the #s are correct to the #s you posted You do have a 1971 RR , But i don't know about the swaybar and mounts. So it would be a good thing to ask over at the Mopar site. Cole |
You can see (at least I could) by the photo that you had the brackets, I don't know what I can tell you- I really didn't think it was necessary to say "see the brackets on the 440's- lower arms? Yours are the same." Glad you found your answer elsewhere. If you're happy- I'm happy. |
From the pic's you posted, I assume someone removed the sway bar for less weight and weight transfer off the line. Look for the brackets on the cross member or frame that hold the center of the bar. They are bolt in not welded. Your car will handle a lot better with the sway bar in with the torsion bar front suspension.
| 4L60E expert level help needed | ca434sbc | Transmission - Rearend | 12 | 10-04-2007 05:44 PM |
| 2004R shifts too high when hot! Expert needed!! | Berliner Bel Air | Transmission - Rearend | 19 | 04-11-2007 07:24 AM |
| MOPAR 440 info needed | 38Chevy3WCoupe | Engine | 8 | 02-18-2007 12:18 AM |
| Supercharged Small Mopar?? | barthmonster | Engine | 1 | 06-23-2006 06:02 PM |
| Mopar IFS | moparist | Suspension - Brakes - Steering | 8 | 03-10-2006 06:50 PM |
