Mopar Help- module???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2003, 11:37 AM
WoodsEdge's Avatar
Posted this before but still have problem. 84 LeBaron conv.- 2.2 Turbo. Will start after much turning over but will not rev up. Don't have a tach but can't be over 5-600rpm. Checked fuel pressure - only 15psi- changed fuel pump- now 50psi. Still same problem. I know nothing about the computors but the book says it has a logic module and a power module. The power module controls the injectors but the logic module controls the power moduls. any susgestions!!
Jack
Oh, and its in time and getting good fire.
Old 08-13-2003, 07:15 PM
NorthStar's Avatar
Locked up turbo or plugged exhaust, maybe.
Old 08-13-2003, 07:35 PM
WoodsEdge's Avatar
I was afraid someone would say turbo. Is there a way to check it with out pulling it off?? What about the power module? Would it cause this??
Thanks, Jack
