Mopar and Nissian
My brother turned me on to the idea of take the trans and carrier (rear end) from a 350z on the back side of my 1973 340 Chrysler small block.
I can understand the trans part just get a custom bell housing but, the carrier is what i have trouble figuring out. The rear ends for my car or everything I've see has leaf springs and is a solid axle. The carrier from the "Z" has spring towers and a cv jointed axle (cv joints). I just wonder how hard or how possible it would be to do or if i could get the same thing out of a Ford 9" or 8.8"? Thanks. |
I'm trying to cause trouble lol. I know the 350z rear ends are really good and not super expensive and the supensension is a lot better.
Right now I have a built 340 and I'm estimating it would push 375 hp to the tires. I've talked talked to some people and they say that I need a new rear end and the the 7-1/4 will snap the first time I get on it. Thanks for all your help |
And yet, you still haven't told us what kind of car this is going into...
"Just get a custom bellhousing..." OK, sure, cause the Nissan-to-Mopar swap is a common one. And as for swapping the independent strut rear suspension from the Z-car, you'll essentially need to cut out the rear floor and inner fenders from the donor car and weld them into your car to transfer all the suspension attach points and geometry. |
I've see a Supra rear suspension swapped into an early Mustang. As I noted, they used the rear floor pan and strut mounts from the donor. Fit great, looked great, but it was a lot of work. Of course, the track width of the two cars needs to be similar.
Also, when i say "just get a custom bell housing" I don't doubt someone will make me one. Quote:
Where abouts in Texas are you? I build rear ends. I also just sold an 'A' body housing about a week ago for 150. Yeah, a bit cheap for an 'A' body housing. They are out there but the price for an original A body housing isn't cheap and you can probably pick up a housing on Craigslist for a B body and have it shortened to what you need for about the same costs as buying the 'A' housing. If you're not too far from the Houston area, find a housing and bring it to me and I'll make it as skinning as you want it...
I'm up in Dallas so Houston is a little bit of a drive and my truck gets horrible milage lol. Also I don't trust my truck to make it there at back I have a buddy that lives in Austin that might be able to help me out. How much you think I could buy a rear end from you for? PM me if that's easier. I'm very interested.
I'm looking right now, i'm also wondering what a good ratio would be, just a good all around, not for racing and not a pansy, just in the middle
A 3.55 is a decent gear for giving the car a little extra kick plus it's not bad for highway use. What's better is to go with an OD trans and deep gears. I ordered a 92 318 Dakota with 3.90 gears and it could have used more but the 3.90 is it from the factory. Also, I ordered our 2000 Durango with a teen and 3.90 gears. At 65 mph, it gets 17 but only 13 at 80. My Dakota was never driven for mileage and it averaged 15. The Durango isn't a blaze of fire at 4600 lbs but runs a 16.40 at the track. The Dakota ran a 15.30 but only weighed 3300. Both are totally stock...and I really like the OD transmissions.
I found this one
http://dallas.craigslist.org/sdf/pts/2394339183.html I don't know if it needs to be skinnied. Is that ratio good or is it higher the number the faster it can go. How does it work? I don't know anything about them. I will be googling it right now but if you would be so kind to post something about it I would be greatful. Thanks |
| Mopar 3.9L V6 | Bucksnortly | Engine | 0 | 01-11-2008 03:40 PM |
| Mopar IFS | moparist | Suspension - Brakes - Steering | 8 | 03-10-2006 06:50 PM |
| Brake lights stay on Nissian 4wd pick up | jlkmorgan | Suspension - Brakes - Steering | 1 | 09-17-2005 11:24 PM |
| Mopar 273/318 | street rodder 1937 | Engine | 8 | 04-28-2004 08:42 AM |
| Cam ?'s Mopar 383 | sledge57 | Engine | 1 | 10-02-2003 10:16 PM |
