mopar rear disc help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2012, 02:48 AM
Last journal entry: Getting there....I think
anyone seen any cheap basic junk yard set up for a rear disc conversion on a mopar 8 3/4?thanks guys
Old 01-10-2012, 01:21 PM
Wiki Edits: 49
If you are working on a post '64 rear end you can adapt late '90s Jeep Cherokee rear disks... but some machining of the axles will be required. Even the early Imperial rear disks require you to change the rear bearings and finding the Imperial units is next to impossible.
Your best bet, if you must have rear disks would be one of the commercially available kits. They're a bit pricy but by the time you pay for the parts and machining on the axles for the Jeep conversion it would probably be a wash.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
mopar disc brakes 55Plaza Suspension - Brakes - Steering 2 04-27-2006 12:25 AM
Can a guy use a disc/disc master with drum rear? MM in NM Suspension - Brakes - Steering 1 12-08-2005 06:08 PM
mopar A body disc brake upgrade 74 swinger Introduce Yourself 2 12-05-2004 12:14 AM
Mopar Rear End Thanks phatwagon Transmission - Rearend 0 05-21-2003 06:27 AM
Mopar Rear Ends phatwagon Transmission - Rearend 2 04-24-2003 03:13 PM
