Mopar Rear Ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2003, 08:32 PM
New Member
Post Mopar Rear Ends
I have two 66 Belvedere Wagons, one with what I consider to be a regular rear end, and the other has a rear end that has a castle nut and cotter pin on the axles. I can't get the brake drums off either. Any clues as how to do a brake job on these?
Old 04-24-2003, 08:48 AM
Post
The drums have to be removed with a wheel puller. Must Mopar owners I know update these read ends..........Good Luck
Old 04-24-2003, 02:13 PM
Post
The rear end that has the castle nut and cotter pin has a hub and drum assembly mounted on a tapered/keyed axle.
The proper way to get them is to use a three-legged hub puller. Remove the castle nut, cotter pin and washer on axle.Mount the legs to 3 of the lug studs/screws and use a fair-size ball pein to knock the lever until the hub "pops" free. An "old-timer's" method is to use a piece of chain about 12-14 feet long with links large enough to accept the lug studs/screws. Remove the castle nut, cotter pin, and washer.Screw 2 or 3 links to the hub. Lay the rest of the chain out in an "ess"-shape. Grab the end and snap it like a bullwhip. If everything is OK you should be able to "pop" it loose with only one or two snaps.
