Mopar Rod Bearing Oil squirter Notch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 07:21 AM
LATECH's Avatar
Building a 360 dodge from a 2000 dodge 1500 pickup. The 360 rod bearings have a notch to spray oil , probably on wrist pin. The new clevite bearings do not have it. What is its true purpose and will not having it cause damage. Looks to me like having it there is a problem as the motor has about 60K on it and the rods were allready on the bronze.The mains were in great shape.
Looks like the rods are starving for pressure.
Old 10-25-2010, 07:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
According to Ma MOPAR, "Each Bearing cap has a small "V" groove across the parting surface. When installing the lower bearing shell, make certain that the "V" groove in the shell is inline with the "V" groove in the cap. This provides lubrication of the cylinder wall in the opposite bank."
This isn't thought to be necessary. Many engines through the years used "spit holes", etc. for flinging oil around (most didn't keep them, though- excepting "new" engines w/dedicated piston oiling shooters and the like), but as long as the rood side clearances are in spec and the same for the lifter to lifter bore, the cam and cylinders will get all the lube they need.
Old 10-25-2010, 08:04 AM
LATECH's Avatar
Thanks Cobalt. Makes good sense what you said. My thinking was to ignore it being missing.Probably wont make any difference.
Old 10-25-2010, 08:27 AM
Wiki Edits: 49
If it was me, I'd take my Clevite bearings back and stop by the local Mopar store and pick up a set you know will be right. You may be fine with the bearings you have but those spitter holes are there for a reason and why take a chance. My $.02 anyway.
Old 10-25-2010, 08:44 AM
LATECH's Avatar
I was trying to find out what there purpose was and if it was effective. Any Idea?
Old 10-25-2010, 10:37 AM
LATECH's Avatar
Thanks again cobalt. Looks like we are opting to run the non notched version. It worked well for years why change now?
Old 10-25-2010, 04:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are the rods also notched? Below is a Hemi rod and bearing:
The PAGE also mentions the spit hole is there to hit the thrust side of the bore and cam w/oil. But I don't see bearings offered w/the holes already in them...
Old 10-25-2010, 04:52 PM
Wiki Edits: 49
Originally Posted by cobalt327
This PAGE also mentions the spit hole is there to hit the thrust side of the bore and cam w/oil. But I don't see bearings offered w/the holes already in them...
Thanks for referencing my web site for that pic. Didn't want to blow my own horn.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 10-25-2010, 06:01 PM
LATECH's Avatar
Yes, the cap is machined with the groove in it.The bearings are also worn as What I suspect is due to excess leakage. JMO.The main bearings looked so good they could have been re used (but wont be)
Centerline... My concern is that the bearings will shed oil too fast with the spit hole present and with the centrifical force of the crank throw sheds oil faster than would a main that is stationary. Given the mains condition and the fact the bronze was showing on the rod bearings I suspect oil is being let go of too fast.
I suppose a high volume pump may help.What are youre thoughts on the condition of the bearings?
Old 10-25-2010, 07:28 PM
Wiki Edits: 49
There are a lot of things that can cause rod bearings to "wear out" and oil starvation is one of them. However, IMHO the spitter holes would not starve the bearings of oil. They were put in there to lubricate the cylinder wall probably because the engineers weren't convinced there would be enough oil splashing on them to do the job. Ma Mopar has been doing this for over 50 years so it might just be something that has carried over "just because its always been done that way". My only point is that if it were me and I was spending the money for a rebuild I'd use bearings that had the notch just to be safe. That said, even if you don't you'll probably be OK.
Old 10-26-2010, 01:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm a little miffed that there seems to be so little mention of this on the interweb. If this was a Chevy "problem", there'd be reams of BS on it...
In any event, I would agree that if there were a problem w/not using the notched bearings, the bearing makers (like Cleveite) would supply both styles.
If it is a concern, you could add a few psi of oil pressure to offset the losses through the notches. I seriously doubt the notches by themselves would warrant a HV pump, but if you're using a pump w/higher psi OR volume than OEM- that will certainly offset that part of the equation.
As for the lubing of the cylinder walls, I would tend to think the 'benefit' would be mostly at low RPM.
Old 10-26-2010, 07:14 PM
LATECH's Avatar
I agree there should have been more chatter about this subject.As it is a mopar it is ignored.This could be an applicable discussion for any engine type.
Clevite finally got back to us and said to run them, no problem.
I have seen where some race guys notch the main thrust bearing on pontiac engines (full out race motors not street motors) to help keep the journal oiled. Oiling is essential to all engines, not just chevrolets
As far as lube for the cylinder walls, It looks as though brad penn will keep enough zddp in there to take care of any minor issue that the oem was trying to compensate for at low rpm.After all this was a 2000 dodge engine so no zinc in there.They bottle that stuff just a few miles from my house
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 08:51 PM
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
Cam Bearing oil hole alignment morenoer Engine 3 04-06-2009 12:55 PM
Need rod bearing help ASAP! PLZ CustomConspiracy Engine 13 12-01-2008 02:46 AM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
