Mopar Speedo Cable Routing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2009, 07:22 PM
Does anyone know the routing for the speedo Cable in a 1964 -1965 B Body Mopar? The car didn't come with one so I have one to put in.
Old 09-13-2009, 12:49 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
This thread almost slipped through the cracks.
Sorry, I do not have a step by step tutorial for you, but if there is no cruise control then the cable simply threads on the back of the speedo and then threads on the speedo drive located on the extension housing of the trans.
As far as routing, safe to say it must pass through the lower fire wall or upper floor area so look for a hole roughly an inch in diameter. Usually cables pass through grommets. Maybe a clip along the frame. Not too tight and no kinks, there a spinning wire in the middle...
Best of luck.
speedo cable problems? 77formulabandit Transmission - Rearend 1 09-02-2008 07:02 PM
How can i extend the speedo cable. 7t2HQ Interior 6 11-19-2004 05:11 PM
