Mopar Water Pumps - are there more than 1 length? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2013, 10:45 AM
Elevinpointsixtoone's Avatar
Hi, Mopar LA engines, the 318/340/360....do they have more than 1 water pump length? I have a Mopar performance pump sitting here that pushes out the pulley mount 5 5/8" as measured from the rear of the body (mounting surface) to the front of the mounting "cross". My old mid 60's pump is 4 5/8"... a full inch shorter. Not sure what to do here.....I need the shorter pump and my old one is craclked.
Thanks,
Dave
Old 02-04-2013, 10:59 AM
Someone just suggested the new pump may be a truck pump, which may be longer? I have no data on what the new pump. Your typical Craigslist offering.....hey at $15 hard to say no.
Old 02-04-2013, 01:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There were two earlier LA water pumps. One is from the mid '60s to early '70s, and is cast iron. The later ~'72-up (longer I believe) LA pump is aluminum. The two earlier pumps have the hose bibs on opposite sides and also use different timing covers IIRC. Once I tried to make a hose to fit an aluminum pump to the earlier radiator and couldn't make anything work.
There's also a late model reverse rotation Magnum pump.
Old 02-04-2013, 01:55 PM
Well that is even more options than I have found to date. What does IIRC refer to? The aluminum pump I picked up was off of a Summit 390 HP Mopar performance 360 that was going in a 90's truck. The buyer had to swap on all of his fuel injection stuff so he had ignition, timing cover and pump for a carb engine he could not use. Now I'm trying to use those on my 66 poly 318. Wanting to a) move the rad inlet to the passenger side and B use a better flow and lighter pump. I've always read that the LA pumps and covers are the same as the poly otherwise.
Old 02-04-2013, 03:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
"IIRC" = If I remember correctly.
On the timing cover, as long as you don't have the mid '50s to '61 cast iron timing cover, you're OK. The CI cover uses a different water pump than any of the others.
There's one bolt hole that's not on the later timing cover that has to be plugged in the Poly block.
Water pumps V8Square Engine 10 04-24-2012 07:38 PM
Water Pumps nootkabear Engine 3 11-08-2007 03:00 PM
4.3 V6 water pumps 40chevcpe Engine 3 10-23-2007 06:53 PM
Water Pumps JJ350 Engine 3 02-21-2007 02:28 PM
Need water pumps. senor_limpio Engine 5 12-02-2002 08:59 PM
