Mopar wiper motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2010, 07:55 PM
Overdriv's Avatar
Mopar wiper motor
I'm helping a friend wire up his wiper motor on a 1967 Plymonth GTX. The motor has three wires coming out of it. They are in the OEM connector Brown, blue and red. Blue will park the wiper when power is applied to it. Red is high speed and red & brown is low speed.
Trying to run it with a Painless switch # 80173 switch
I don't see how it will work with this switch. Hoping someone can post a wiring schematic or shed some light on how it should be wired.
Old 02-22-2010, 08:19 AM
Joe G's Avatar
Seems like the right switch to me...
Are the terminals on the back of the switch marked? The info in the link you provided indicates that the terminals are probably marked P,W,1,2, and 3.
If that's the case, wire it as follows:
Fused, key-on power goes to the "P" terminal,
Blue Park wire to the "3" terminal,
Brown Low speed wire to the "2" terminal,
and Red Hi speed wire to the "1" terminal.
And of course, if you have a windshield washer pump, it gets it's power from the "W" terminal.
Hope this helps...
Old 02-22-2010, 09:39 AM
Overdriv's Avatar
Joe, that's what I thought at first too. But to get low speed, both terminals 1 and 2 have to have 12V on them. The switch supples 12V to either/or, but not both at once???
Old 02-22-2010, 09:55 AM
Joe G's Avatar
Sorry...I guess I misread your post. You can still make it work if you use a relay, or maybe just a diode. I'll post a diagram tonight unless someone beats me to it.
Joe
Old 02-22-2010, 11:09 AM
Overdriv's Avatar
A diode would be the easiest. I was wondering if there was a different switch available. I googled this am and didn't find anything that sounded like it would work.
Thanks for the reply.
Old 02-22-2010, 11:04 PM
Joe G's Avatar
The proper switch would definitely be the best way to go.
The only ones I could find were on Ebay:
link 1
link 2
You might be able to connect a very large diode between the red and brown wires, but it will get hot, and it might overheat or melt something. There is also the problem that for the first fraction of a second when the motor is turned on, there is a large current spike that might blow the diode. The more I think about it, the diode is probably not a good idea.
Good luck...
Old 02-22-2010, 11:08 PM
Overdriv's Avatar
You don't think a 10A diode would work? I don't know what that motor pulls when it runs??
Old 02-23-2010, 08:20 AM
Joe G's Avatar
The motor probably doesn't pull more than 3-4 amps on low, but for the first 1/10th of a second it could draw 20 or more amps. I'm not sure if the diode could handle that initial surge or if it would blow instantly. You could try it, maybe it will be fine. I just don't want to say conclusively that it will work, because I'm not sure.
Old 02-23-2010, 08:23 AM
Overdriv's Avatar
I think I'll try it and if it fails I'll just install a relay and be done with it. Thanks for your replys.
Wiring New Port wiper motor to GM column bnewsom Electrical 1 08-25-2007 06:43 PM
wiper motor wiring 37 plymouth coupe Electrical 4 07-27-2007 11:30 AM
Wiring a Volkswagon wiper motor wheel-7 Electrical 4 07-01-2007 06:18 PM
Chevy AD Truck Wiper Motor Question bigfred1958 Interior 1 11-12-2004 04:49 PM
wiper motor for 37 ford Sedan bgal Electrical 1 12-21-2002 03:20 PM
